#31 | ||
you have dirty injectors
#32 | ||||
Cheers, Jeff http://www.aufalcon.com/ubuxkl |
#33 | |||
At the service they did in January, they hooked up the computer and it didn't return any faults. What a pain. The damn thing drives beautifully but I hate having things like this ![]() ![]()
#34 | |||
Next upgraded Mk1 Leopard
![]() Join Date: Jan 2005
UK
#35 | |||
Dirty or leaking injectors do not show up any codes.
#36 | ||
AU's tend to get loosening of the inlet manifold bolts, which gives the same sort of symptoms as a buggered inlet gasket, so it's worth getting a size 10 spanner and giving the ones you can get to a good tightening.
#37 | |||
#38 | ||
Mine starting doing this when I got an aftermarket exhaust. Haven't been able to work it out yet. I've replaced the coil pack, oxy sensor, plugs and leads so I know they aren't involved.
#39 | |||
Nitro
I was about to say adjust the throttle body stop screw like I did and for me it stopped the rev hang when stopping and all the hesitation disappeared just from a little turn of a screw....after all the new components I replaced ISC TPS coil packs leads plugs hahaha for me it was just a 1/4 turn of the stop screw and she idles and drives beautifully now.. Anyway going to go and check myself into a mental institution now my brain is fried. |
#40 | |||
![]() Join Date: Oct 2006
regards Blue Last edited by aussiblue; 23-11-2020 at 08:34 PM. |
#41 | ||
my au xr6 hesitates at idle and runs perfect i squirted soapy water around the rear of engine between the gap in the inlet manifold and it instantly ran on 5 cyclinders. whats going on ?
#42 | ||
Looks like you've found a vacuum leak.
If you weren't looking for a vacuum leak. Why would you be squirting soapy water on the engine? What did you expect to happen? |
#43 | ||
someone mentioned inlet manifold leak and said to use soapy water in a squirt bottle im hoping its an leaking injector.at least i can tell the mech what i did when he comes to pick the car up once before ive degreased the engine and hosed it off with no problems
#44 | |||
#neuteredlyfe
![]() ![]() Join Date: Apr 2012
An inlet manifold gasket is a lot cheaper and easier to fix being a $25 job and takes about an hour to replace if you don't know what you are doing. |
#45 | ||
thanks. thats great news i thought it was the other way around i drove it today and it was good. no problem but i know it will re surface iread that the gasket is a common fault
