23-12-2019, 01:33 PM | #1 | ||
Frankenford pilot
Hey guys, this is a small walk through on using https://postimage.org/
I use a IPad for most things and find this to be the simplest way to post images. You will need to set up a free account. From there you upload from your device to your postimage account. Select the image size, I found “15 inch monitor” a good over all size, then hit the upload tab. From there your directed to choose a link to copy and paste into your post. This method will post a single image. To post multiple images use the following method. Choose the images you want to use, upload to post image and follow the directions below. Then hit the colum tab to copy and paste into your post. This method will post multiple images, one under the other. You can enter text between the images after you copy and paste into your post. If I’ve forgotten anything please feel free to add your tips. Hope this helps anyone that’s having trouble or looking for a very easy way to post images. It’s so easy, even a simple panel beater can do it, or even an ol truck driver
Cheers Bretto 73 XB GT Last of the Big Ports |
18 users like this post: |
06-01-2024, 06:11 PM | #2 | |||
Gassa |
06-01-2024, 08:58 PM | #3 | ||
Regular...with metamusal
06-01-2024, 09:14 PM | #4 | ||
Postimage is a web portal. There are no drivers required. If you downloaded an app, delete it.
~~~~~~~~~~~~~~ Rides (past and present) Current: 2004 Ford Falcon 5.4L 3v Barra 220, Manual Past: Mitsubishi Sigma (m), Toyota Seca (m), Toyota Seca SX (m), Toyota Vienta V6 (m), Toyota Soarer 4L v8 (a), BA XR8 ute (m), T3 TE50 (m), BMW Z4 (m) AFF motto - If contrary views trigger, please use ignore button. |
